Perturbations and Vertex Removal in a 3D Delaunay Triangulation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
Olivier Devillers
Monique Teillaud
Though Delaunay triangulations are very well known geometric data structures, the problem of the robust removal of a vertex in a three-dimensional Delaunay triangulation is still a problem in practice. We propose a simple method that allows to remove any vertex even when the points are in very degenerate configurations. The solution is available in CGAL (http://www.cgal.org, releases 2.3 and 2.4).
soda.pdf (143.13 Ko) Télécharger le fichier
inria-00166710 , version 1 (08-08-2007)
inria-00166710 , version 2 (21-12-2012)
  • HAL Id : inria-00166710 , version 1
Olivier Devillers, Monique Teillaud. Perturbations and Vertex Removal in a 3D Delaunay Triangulation. 14th ACM-Siam Symp. on Algorithms (SODA), 2003, Baltimore, MA, United States. pp.313--319. ⟨inria-00166710v1⟩
335 Consultations
1054 Téléchargements
