Convergence analysis of the Böl-Reese discrete model for rubber - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2007
In a recent work, Böl and Reese have introduced a discrete model for polymer networks by means of a finite element modeling. They have also provided a comparison with real experiments. A key parameter of their model is the size h of the finite element mesh, that is meant to be small in practice. The aim of the present work is to study the asymptotic behaviour (and the convergence of the finite element method) when the meshsize goes to zero. In particular, we address the properties satisfied by the model at the limit, depending on the properties of the mesh.
proc.pdf (197.42 Ko) Télécharger le fichier
inria-00166846 , version 1 (10-08-2007)
inria-00166846 , version 2 (10-08-2007)
inria-00166846 , version 3 (13-08-2007)
inria-00166846 , version 4 (23-10-2007)
  • HAL Id : inria-00166846 , version 1
  • ARXIV : 0708.1425
Roberto Alicandro, Marco Cicalese, Antoine Gloria. Convergence analysis of the Böl-Reese discrete model for rubber. 2007. ⟨inria-00166846v1⟩
245 Consultations
56 Téléchargements
