Randomization Yields Simple $O(n \log^{\star} n)$ Algorithms for Difficult $\Omega(n)$ Problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Computational Geometry and Applications Année : 1992
Olivier Devillers
We use here the results on the influence graph to adapt them for particular cases where additional information is available. In some cases, it is possible to improve the expected randomized complexity of algorithms from O(n log n) to O(n log* n). This technique applies in the following applications: triangulation of a simple polygon, skeleton of a simple polygon, Delaunay triangulation of points knowing the EMST (euclidean minimum spanning tree).
hal.pdf (178.06 Ko) Télécharger le fichier
inria-00167206 , version 1 (16-08-2007)
Olivier Devillers. Randomization Yields Simple $O(n \log^{\star} n)$ Algorithms for Difficult $\Omega(n)$ Problems. International Journal of Computational Geometry and Applications, 1992, 2 (1), pp.97-111. ⟨10.1142/S021819599200007X⟩. ⟨inria-00167206⟩
161 Consultations
546 Téléchargements
