Grid-based Localization and Online Mapping with Moving Object Detection and Tracking - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we present a real-time algorithm for local simultaneous localization and mapping (SLAM) with detection and tracking of moving objects (DATMO) in dynamic outdoor environments from a moving vehicle equipped with laser sensor, radar and odometry. To correct vehicle location from odometry we introduce a new fast implementation of incremental scan matching method that can work reliably in dynamic outdoor environments. After a good vehicle location is estimated, the surrounding map of the vehicle is updated incrementally and moving objects are detected without a priori knowledge of the targets. Detected moving objects are finally tracked by a Multiple Hypothesis Tracker (MHT) coupled with an adaptive Interacting Multiple Models filter. The experimental results on datasets collected from different scenarios such as: urban streets, country roads and highways demonstrate the efficiency of the proposed algorithm.
rr.pdf (609.83 Ko) Télécharger le fichier
inria-00167687 , version 1 (22-08-2007)
inria-00167687 , version 2 (29-08-2007)
inria-00167687 , version 3 (05-09-2008)
  • HAL Id : inria-00167687 , version 2
Julien Burlet, Trung Dung Vu, Olivier Aycard. Grid-based Localization and Online Mapping with Moving Object Detection and Tracking. [Research Report] RR-6276, 2007. ⟨inria-00167687v2⟩
211 Consultations
2012 Téléchargements
