Building a Virtual Globus Grid in a Reconfigurable Environment - A case study: Grid5000 - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Reports (Technical Report) Year : 2007
With the continuous evolution of distributed computing grids and with the perpetuous development of the available computing resources and protocols, there is a \textit{sine qua non} requirement to pass beyond the physical design of the grids. A viable solution is offered by virtual grids, having the advantage of flexible mapping and adaptation to live in-place resources. A software image is proposed, built with the use of the Globus Toolkit, the herein document describing the construction and configuratin phases as well as the deployment protocol in a live grid - Grid5000.
buildingAGlobusVGrid.pdf (486 Ko) Télécharger le fichier
Dates and versions
inria-00168130 , version 1 (13-11-2007)
Identifiers
  • HAL Id : inria-00168130 , version 1
Cite
Alexandru-Adrian Tantar, Nouredine Melab, Christophe Demarey, El-Ghazali Talbi. Building a Virtual Globus Grid in a Reconfigurable Environment - A case study: Grid5000. [Technical Report] 2007, pp.24. ⟨inria-00168130⟩
171 View
454 Download
Share
