Characterization of graphs and digraphs with small process number - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The process number of a digraph has been introduced as a tool to study rerouting issues in WDM networks. We consider the recognition and the characterization of (di)graphs with process number at most two.
squelette-rr.pdf (360.85 Ko) Télécharger le fichier
inria-00171083 , version 1 (11-09-2007)
inria-00171083 , version 2 (11-09-2007)
inria-00171083 , version 3 (12-09-2007)
inria-00171083 , version 4 (29-01-2008)
  • HAL Id : inria-00171083 , version 2
David Coudert, Jean-Sébastien Sereni. Characterization of graphs and digraphs with small process number. [Research Report] RR-6285, 2007, pp.25. ⟨inria-00171083v2⟩
Collections
INRIA-RRRT
249 Consultations
175 Téléchargements
