A variational method for joint tracking of curve and motion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Nicolas Papadakis
Etienne Mémin
  • Fonction : Auteur
  • PersonId : 952791
In this paper, a new framework for the tracking of closed curves and their associated motion fields is described. The proposed approach enables a continuous tracking along an image sequence of both a deformable curve and velocity field. Such an approach is formalized through the minimization of a global spatio-temporal continuous cost functional, w.r.t a set of variables representing the curve and its related motion field. Relying on an optimal control technique, the resulting minimization sequence consists in a forward integration of an evolution law followed by a backward integration of an adjoint evolution model. This latter pde includes a term related to the discrepancy between the state variables evolution law and discrete noisy measurements of the system. The closed curves are represented through implicit surface modeling, whereas the motion is described either by a vector field or through vorticity and divergence maps depending on the kind of targeted applications. The efficiency of the approach is demonstrated on two types of image sequences showing deformable objects and fluid motions.
RR-6283.pdf (2.26 Mo) Télécharger le fichier
inria-00171087 , version 1 (11-09-2007)
inria-00171087 , version 2 (12-09-2007)
  • HAL Id : inria-00171087 , version 2
Nicolas Papadakis, Etienne Mémin. A variational method for joint tracking of curve and motion. [Research Report] RR-6283, INRIA. 2007, pp.45. ⟨inria-00171087v2⟩
193 Consultations
121 Téléchargements
