Kahan's algorithm for a correct discriminant computation at last formally proven - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Computers Année : 2009
This article tackles Kahan's algorithm to compute accurately the discriminant whatever the inputs. This is a known difficult problem and this algorithm leads to an error bounded by 2 ulps of the result. The proofs involved are long and tricky and even trickier than expected as the test involved may give an unexpected result. We give here the total demonstration of the validity of this algorithm and we provide sufficient conditions to guarantee neither Overflow, nor Underflow will jeopardize the result. The program was annotated using the Caduceus tool and the proof obligations were done using the Coq automatic proof checker.
boldo.pdf (629.21 Ko) Télécharger le fichier
inria-00171497 , version 1 (12-09-2007)
inria-00171497 , version 2 (24-11-2009)
Sylvie Boldo. Kahan's algorithm for a correct discriminant computation at last formally proven. IEEE Transactions on Computers, 2009, 58 (2), pp.220-225. ⟨10.1109/TC.2008.200⟩. ⟨inria-00171497v2⟩
422 Consultations
747 Téléchargements
