On Frequency Optimisation for Power Saving in WSNs: Finding Optimum Hardware Timers Frequencies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2007
Wireless Sensor Networks research and demand are now in full expansion, since people came to understand these are the key to a large number of issues in industry, commerce, home automation, healthcare, agriculture and environment, monitoring, public safety etc. One of the most challenging research problems in sensor networks research is power awareness and power-saving techniques. In this master's thesis, we have studied one particular power-saving technique, i.e. frequency scaling. In particular, we analysed the close relationship between clock frequencies in a microcontroller and several types of constraints imposed on these frequencies, e.g. by other components of the microcontroller, by protocol specifications, by external factors etc. Among these constraints, we were especially interested in the ones imposed by the timer service and by the serial ports' transmission rates. Our efforts resulted in a microcontroller configuration management tool which aims at assisting application programmers in choosing microcontroller configurations, in function of the particular needs and constraints of their application.
rapport_INRIA.pdf (976 Ko) Télécharger le fichier
rapport_master.pdf (1.14 Mo) Télécharger le fichier
soutenance_master.pdf (5.54 Mo) Télécharger le fichier
Format : Autre
Format : Autre
inria-00172015 , version 1 (13-09-2007)
inria-00172015 , version 2 (14-09-2007)
inria-00172015 , version 3 (15-09-2007)
inria-00172015 , version 4 (17-09-2007)
  • HAL Id : inria-00172015 , version 2
Andreea Maria Picu, Antoine Fraboulet, Eric Fleury. On Frequency Optimisation for Power Saving in WSNs: Finding Optimum Hardware Timers Frequencies. [Internship report] 2007, pp.42. ⟨inria-00172015v2⟩
196 Consultations
665 Téléchargements
