Regularity results for the Primitive Equations of the ocean
We consider the linear Primitive Equations of the ocean in the three dimensional space, with horizontal periodic and vertical Dirichlet boundary conditions. Thanks to Fourier transforms we are able to calculate explicitly the pressure term. We then state existence, unicity and regularity results for the linear time-depending Primitive Equations, with low-regularity right-hand side.
