On the adaptation of the noise level for stochastic optimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Olivier Teytaud
Anne Auger
  • Fonction : Auteur
  • PersonId : 751513
  • IdHAL : anne-auger
This paper deals with the optimization of noisy fitness functions, where the noise level can be reduced by increasing the computational effort. We theoretically investigate the question of the control of the noise level. We analyse two different schemes for an adaptive control and prove sufficient conditions ensuring the existence of an homogeneous Markov chain, which is the first step to prove linear convergence when dealing with non-noisy fitness functions. We experimentally validate the relevance of the homogeneity criterion. Large-scale experiments conclude to the efficiency in a difficult framework.
markovnoise.pdf (2.7 Mo) Télécharger le fichier
inria-00173224 , version 1 (19-09-2007)
  • HAL Id : inria-00173224 , version 1
Olivier Teytaud, Anne Auger. On the adaptation of the noise level for stochastic optimization. IEEE Congress on Evolutionary Computation, 2007, Singapour, Singapore. ⟨inria-00173224⟩
164 Consultations
155 Téléchargements
