On the hardness of offline multiobjective optimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Evolutionary Computation Année : 2007
Olivier Teytaud
It is empirically established that multiobjective evolutionary algorithms do not scale well with the number of conflicting objectives. We here show that the convergence rate of all comparison-based multiobjective algorithms, for the Hausdorff distance, is not much better than the convergence rate of the random search, unless the number of objectives is very moderate, in a framework in which the stronger assumptions are (i) that the objectives are conflicting (ii) that lower bounding the computational cost by the number of comparisons is a good model. Our conclusions are (i) the relevance of the number of conflicting objectives (ii) the relevance of criteria based on comparisons with random-search for multi-objective optimization (iii) the very-hardness of more than 3- objectives optimization (iv) some hints about cross-over operators.
pareto2.pdf (228.74 Ko) Télécharger le fichier
inria-00173239 , version 1 (19-09-2007)
  • HAL Id : inria-00173239 , version 1
Olivier Teytaud. On the hardness of offline multiobjective optimization. Evolutionary Computation, 2007. ⟨inria-00173239⟩
200 Consultations
466 Téléchargements
