Impact of NUMA Effects on High-Speed Networking with Multi-Opteron Machines - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
The ever-growing level of parallelism within the multi-core and multi-processor nodes in clusters leads to the generalization of distributed memory banks and busses with non-uniform access costs. These NUMA effects have been mostly studied in the context of threads scheduling and are known to have an influence on high-performance networking in clusters. We present an evaluation of their impact on communication performance in multi-Opteron machines. NUMA effects exhibit a strong and asymmetric impact on high-bandwidth communications while the impact on latency remains low. We then describe the implementation of an automatic NUMA-aware placement strategy which achieves as good communication performance as a careful manual placement, and thus ensures performance portability by gathering hardware topology information and placing communicating tasks accordingly.
PDCS07.pdf (98.45 Ko) Télécharger le fichier
inria-00175747 , version 1 (01-10-2007)
  • HAL Id : inria-00175747 , version 1
Stéphanie Moreaud, Brice Goglin. Impact of NUMA Effects on High-Speed Networking with Multi-Opteron Machines. PDCS, Nov 2007, Cambridge, United States. ⟨inria-00175747⟩
270 Consultations
1612 Téléchargements
