Battling windmills with Coq: formal verification of a compilation algorithm for parallel moves - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2007
This article describes the formal verification of a compilation algorithm that transforms parallel moves (parallel assignments between variables) into a semantically-equivalent sequence of elementary moves. Two different specifications of the algorithm are given: an inductive specification and a functional one, each with its correctness proofs. A functional program can then be extracted and integrated in the Compcert verified compiler.
pmov.pdf (238.24 Ko) Télécharger le fichier
inria-00176007 , version 1 (02-10-2007)
  • HAL Id : inria-00176007 , version 1
Laurence Rideau, Bernard P. Serpette, Xavier Leroy. Battling windmills with Coq: formal verification of a compilation algorithm for parallel moves. 2007. ⟨inria-00176007⟩
157 Consultations
151 Téléchargements
