On extended regular expressions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
In this paper we extend the work of Campeanu, Salomaa and Yu on extended regular expressions featured in the Unix utility egrep and the popular scripting language Perl. We settle the open issue of closure under intersection and provide an improved pumping lemma that will show that a larger class of languages is not recognizable by extended regular expressions.
notes_on_extended_regexp.pdf (82.14 Ko) Télécharger le fichier
inria-00176043 , version 1 (02-10-2007)
  • HAL Id : inria-00176043 , version 1
Benjamin Carle, Paliath Narendran, Colin Scheriff. On extended regular expressions. UNIF07, 2007, Paris, France. ⟨inria-00176043⟩
Collections
UNIF07
89 Consultations
678 Téléchargements
