Finite time observers: application to secure communication
In this paper, control theory is used to formalize finite time chaos synchronization as a nonlinear finite time observer design issue. This paper introduces a finite time observer for nonlinear systems that can be put into a linear canonical form up to output injection. The finite time convergence relies on the homogeneity properties of nonlinear systems. The observer is then applied to the problem of secure data transmission based on finite time chaos synchronization and the two-channel transmission method.
Automatique
