Secure data transmission based on multi-input multi-output delayed chaotic system - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International journal of bifurcation and chaos in applied sciences and engineering Année : 2007
This paper deals with the problem of secure data transmission based on multi-input multi-output delayed chaotic systems. A new multi-input secure data transmission scheme is proposed. Moreover, in order to increase again the robustness of secure data transmission, some delays areintroduced as a second firewall against known plain-text attack. With thismethod, the parameters used as secret keys of the system are not identifiable and, as a result, the proposed scheme is robust to known plain-text attacks.
Automatique
IJBC_HAL.pdf (188.48 Ko) Télécharger le fichier
inria-00176896 , version 1 (04-10-2007)
inria-00176896 , version 2 (23-10-2007)
  • HAL Id : inria-00176896 , version 1
Gang Zheng, Driss Boutat, Thierry Floquet, Jean-Pierre Barbot. Secure data transmission based on multi-input multi-output delayed chaotic system. International journal of bifurcation and chaos in applied sciences and engineering , 2007. ⟨inria-00176896v1⟩
Collections
X
495 Consultations
301 Téléchargements
