Differential invariants of a Lie group action: syzygies on a generating set - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2007
Evelyne Hubert
We elaborate on the reinterpretation of Cartan's moving frame by Fels and Olver (1999) as an equivariant map. A moving frame allow to construct invariant derivations and differential invariants. We exhibit a complete set of syzygies for a generating (finite) subset of those latter.
hal.inria.00178189v2.pdf (405.97 Ko) Télécharger le fichier
inria-00178189 , version 1 (10-10-2007)
inria-00178189 , version 2 (23-10-2007)
inria-00178189 , version 3 (06-12-2007)
inria-00178189 , version 4 (04-09-2008)
inria-00178189 , version 5 (03-11-2008)
  • HAL Id : inria-00178189 , version 2
  • ARXIV : 0710.4318
Evelyne Hubert. Differential invariants of a Lie group action: syzygies on a generating set. 2007. ⟨inria-00178189v2⟩
213 Consultations
619 Téléchargements
