How to compare arc-annotated sequences: The alignment hierarchy - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
We describe a new unifying framework to express comparison of arc-annotated sequences, which we call alignment of arc-annotated sequences. We first prove that this framework encompasses main existing models, which allows us to deduce complexity results for several cases from the literature. We also show that this framework gives rise to new relevant problems that have not been studied yet. We provide a thorough analysis of these novel cases by proposing two polynomial time algorithms and an NP-completeness proof. This leads to an almost exhaustive study of alignment of arc-annotated sequences.
hal.pdf (345.76 Ko) Télécharger le fichier
inria-00178671 , version 1 (21-11-2011)
  • HAL Id : inria-00178671 , version 1
Guillaume Blin, Helene Touzet. How to compare arc-annotated sequences: The alignment hierarchy. 13th String Processing and Information Retrieval, Oct 2006, Glasgow, United Kingdom. pp.291-303. ⟨inria-00178671⟩
217 Consultations
247 Téléchargements
