Qualitative response of interaction networks: application to the validation of biological models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
We advocate the use of qualitative models for the analysis of shift equilibria in large biological systems. We present a mathematical method, allowing qualitative predictions to be made of the behaviour of a biological system. These predictions are not dependent on specific values of the kinetic constants. We show how these methods can be used to improve understanding of a complex regulatory system.
ICIAM.pdf (85.88 Ko) Télécharger le fichier
inria-00178854 , version 1 (12-10-2007)
  • HAL Id : inria-00178854 , version 1
Anne Siegel, Carito Guziolowski, Philippe Veber, Ovidiu Radulescu, Michel Le Borgne. Qualitative response of interaction networks: application to the validation of biological models. 6th International Congress on Industrial and Applied Mathematics. ICIAM 07, Jul 2007, Zurich, Switzerland. ⟨inria-00178854⟩
221 Consultations
147 Téléchargements
