Finiteness properties for Pisot $S$-adic tilings - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Pierre Arnoux
  • Fonction : Auteur
  • PersonId : 843356
Valerie Berthe
In this paper, we will first formulate and prove some equivalent sufficient conditions to obtain the tiling property for a Pisot unimodular substitution. We will then apply these condition to the more general framework of adic systems, to extend to this more general (and non algebraic) case results already known for the substitutive case.
ABS-JM.pdf (168.31 Ko) Télécharger le fichier
inria-00180242 , version 1 (18-10-2007)
  • HAL Id : inria-00180242 , version 1
Pierre Arnoux, Valerie Berthe, Anne Siegel. Finiteness properties for Pisot $S$-adic tilings. Journées Montoises d'Informatique Théorique, Aug 2006, RENNES, France. ⟨inria-00180242⟩
152 Consultations
87 Téléchargements
