Intentional Motion On-line Learning and Prediction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Machine Vision and Applications Année : 2008
Predicting motion of humans, animals and other objects which move according to internal plans is a challenging problem. Most existing approaches operate in two stages: a) learning typical motion patterns by observing an environment and b) predicting future motion on the basis of the learned patterns. In existing techniques, learning is performed off-line, hence, it is impossible to refine the existing knowledge on the basis of the new observations obtained during the prediction phase. We propose an approach which uses Hidden Markov Models to represent motion patterns. It is different from similar approaches because it is able to learn and predict in a concurrent fashion thanks to a novel approximate learning approach, based on the Growing Neural Gas algorithm, which estimates both HMM parameters and structure. The found structure has the property of being a planar graph, thus enabling exact inference in linear time with respect to the number of states in the model. Our experiments demonstrate that the technique works in real-time, and is able to produce sound long-term predictions of people motion.
Autre [cs.OH]
main.pdf (985.78 Ko) Télécharger le fichier
inria-00181663 , version 1 (24-10-2007)
inria-00181663 , version 2 (27-02-2008)
  • HAL Id : inria-00181663 , version 1
Dizan Alejandro Vasquez Govea, Thierry Fraichard, Olivier Aycard, Christian Laugier. Intentional Motion On-line Learning and Prediction. Machine Vision and Applications, 2008. ⟨inria-00181663v1⟩
199 Consultations
419 Téléchargements
