Purely Periodic beta-Expansions in the Pisot Non-unit Case - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Number Theory Année : 2007
Valerie Berthe
It is well known that real numbers with a purely periodic decimal expansion are rationals having, when reduced, a denominator coprime with $10$. The aim of this paper is to extend this result to beta-expansions with a Pisot base beta which is not necessarily a unit. We characterize real numbers having a purely periodic expansion in such a base. This characterization is given in terms of an explicit set, called a generalized Rauzy fractal, which is shown to be a graph-directed self-affine compact subset of non-zero measure which belongs to the direct product of Euclidean and $p$-adic spaces.
shift.pdf (281.32 Ko) Télécharger le fichier
inria-00181997 , version 1 (24-10-2007)
Valerie Berthe, Anne Siegel. Purely Periodic beta-Expansions in the Pisot Non-unit Case. Journal of Number Theory, 2007, 127 (2), pp.153-172. ⟨10.1016/j.jnt.2007.07.005⟩. ⟨inria-00181997⟩
461 Consultations
118 Téléchargements
