Experimental validation of FastSLAM algorithm characterized by a linear feature based map - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
In this paper the Simultaneous Localization and Mapping Problem in an unknown indoor environment is addressed. A probabilistic approach based on FastSLAM algorithm and line feature map is described. Experimental results performed with a real mobile base in an indoor environment are introduced and discussed.
Autre [cs.OH]
Longhi_Syroco_2006.pdf (770.95 Ko) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
inria-00182010 , version 1 (24-10-2007)
  • HAL Id : inria-00182010 , version 1
Chiara Fulgenzi, Gianluca Ippoliti, Sauro Longhi. Experimental validation of FastSLAM algorithm characterized by a linear feature based map. Proc. of the IEEE/IFAC Symposium on Robot Control (SYROCO), 2006, Bologna, Italy. ⟨inria-00182010⟩
55 Consultations
182 Téléchargements
