Absolute Localization Of Cycab - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2005
The project is about the software realization of a localization system for CyCab as part of an undergraduate internship. The platform used was the CyCabTK simulator where reflective landmarks were used in the localization. The positions of the landmarks are known. Disambiguation of the landmarks is by using the triangle related properties formed by 3 landmarks.
Autre [cs.OH]
IA_report.pdf (492.22 Ko) Télécharger le fichier
inria-00182033 , version 1 (24-10-2007)
  • HAL Id : inria-00182033 , version 1
Gerald Chong Chin Hui. Absolute Localization Of Cycab. [Technical Report] 2005. ⟨inria-00182033⟩
72 Consultations
225 Téléchargements
