A theoretical comparison of probabilistic and biomimetic models of mobile robot navigation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
This paper deals with the domain of space modeling for mobile robotics. It offers a comparison of probabilistic and biomimetic models of navigation. Both approaches are shown to be quite complementary: while the probabilistic methods exploit sound theoretical grounds, they lack the modularity and, as a consequence, flexibility, of their biomimetic counterparts. We propose a new formalism, called the Bayesian Map formalism, that attempts to bridge the gap between the two domains: it is based on Bayesian modeling and inference for defining the building blocks, and uses operators for building hierarchies of models.
Autre [cs.OH]
diard04b.pdf (268.58 Ko) Télécharger le fichier
inria-00182051 , version 1 (24-10-2007)
  • HAL Id : inria-00182051 , version 1
Julien Diard, Pierre Bessiere, Emmanuel Mazer. A theoretical comparison of probabilistic and biomimetic models of mobile robot navigation. Proc. of the IEEE Int. Conf. on Robotics and Automation, Apr 2004, New Orleans, LA (US), France. ⟨inria-00182051⟩
61 Consultations
215 Téléchargements
