Motion Prediction for Moving Objects: a Statistical Approach
This paper proposes a technique to obtain long term estimates of the motion of a moving object in a structured environment. Objects moving in such environments often participate in typical motion patterns which can be observed consistently. Our technique learns those patterns by observing the environment and clustering the observed trajectories using any pairwise clustering algorithm. We have implemented our technique using both simulated and real data coming from a vision system. The results show that the technique is general, produces long-term predictions and is fast enough for its use in real time applications.
Autre [cs.OH]
893.pdf (656.61 Ko)
Télécharger le fichier
893-Digest.ppt (199.5 Ko)
Format : Autre
