Long-Run Cost Analysis byApproximation of Linear Operators over Dioids - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
David Cachera
Pascal Sotin
We present a static analysis technique for modeling and approxi- mating the long-run resource usage of programs. The approach is based on a quantitative semantic framework where programs are represented as linear op- erators over dioids. We show how to extract the long-run cost of a program from the matrix representation of its semantics. An essential contribution is to provide abstraction techniques which make it feasible to compute safe over- approximations of this cost. A theorem is proved stating that such abstractions yield correct approximations of the program's long-run cost. The theoretical developments are illustrated on a concrete example taken from the analysis of the cache behaviour of a simple bytecode language.
RRcachera.pdf (283.38 Ko) Télécharger le fichier
inria-00182338 , version 1 (25-10-2007)
inria-00182338 , version 2 (26-10-2007)
inria-00182338 , version 3 (25-01-2008)
inria-00182338 , version 4 (25-01-2008)
  • HAL Id : inria-00182338 , version 1
David Cachera, Thomas Jensen, Pascal Sotin. Long-Run Cost Analysis byApproximation of Linear Operators over Dioids. [Research Report] 2007, pp.29. ⟨inria-00182338v1⟩
370 Consultations
258 Téléchargements
