Complexity of Delaunay Triangulation for Points on Lower-dimensional~Polyhedra - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Nina Amenta
  • Fonction : Auteur
  • PersonId : 835271
Dominique Attali
We show that the Delaunay triangulation of a set of points distributed nearly uniformly on a polyhedron (not necessarily convex) of dimension p in d-dimensional space is O(n^(d-1)/p))$. For all p between 2 and d-1, this improves on the well-known worst-case bound of $O(n^ceil(d/2))$.
camera.pdf (156.94 Ko) Télécharger le fichier
inria-00182835 , version 1 (29-10-2007)
inria-00182835 , version 2 (08-11-2007)
  • HAL Id : inria-00182835 , version 1
Nina Amenta, Dominique Attali, Olivier Devillers. Complexity of Delaunay Triangulation for Points on Lower-dimensional~Polyhedra. 18th ACM-SIAM Sympos. Discrete Algorithms, Jan 2007, New Orleans, United States. pp.1106--1113. ⟨inria-00182835v1⟩
595 Consultations
537 Téléchargements
