Robust Circle Detection - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
In this paper we present a method of robustly detect circles in a line drawing image. The method is fast, robust and very reliable, and is capable of assessing the quality of its detection. It is based on Random Sample Consensus minimization, and uses techniques that are inspired from object tracking in image sequences.
icdar2007.pdf (188.9 Ko) Télécharger le fichier
inria-00184490 , version 1 (31-10-2007)
Bart Lamiroy, Olivier Gaucher, Laurent Fritz. Robust Circle Detection. 9th International Conference on Document Analysis and Recognition - ICDAR'07, IAPR, Sep 2007, Curitiba, Brazil. pp.526-530, ⟨10.1109/ICDAR.2007.4378765⟩. ⟨inria-00184490⟩
293 Consultations
3136 Téléchargements
