Performance Bounds for Lambda Policy Iteration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Bruno Scherrer
We consider the discrete-time infinite-horizon discounted stationary optimal control problem formalized by Markov Decision Processes. We study Lambda Policy Iteration, a family of algorithms parameterized by lambda, originally introduced by Ioffe and Bertsekas. Lambda Policy Iteration generalizes the standard algorithms Value Iteration and Policy Iteration, and has some connections with TD(Lambda) introduced by Sutton & Barto. We consider the discrete-time infinite-horizon discounted stationary optimal control problem formalized by Markov Decision Processes. We study Lambda Policy Iteration, a family of algorithms parameterized by lambda, originally introduced by Ioffe and Bertsekas. Lambda Policy Iteration generalizes the standard algorithms Value Iteration and Policy Iteration, and is closely related to TD(lambda) introduced by Sutton and Barto. We deepen the original theory developped by Ioffe and Bertsekas by providing convergence rate bounds which generalize standard bounds for Value Iteration described for instance by Puterman. We also develop the theory of this algorithm when it is used in an approximate form. Doing so, we extend and unify the separate analyses developped by Munos for Approximate Value Iteration and Approximate Policy Iteration. The main contribution of this paper is that we show that doing Approximate Lambda Policy Iteration is sound.
lpi.pdf (431.05 Ko) Télécharger le fichier
inria-00185271 , version 1 (05-11-2007)
inria-00185271 , version 2 (09-11-2007)
inria-00185271 , version 3 (13-11-2007)
inria-00185271 , version 4 (03-10-2011)
inria-00185271 , version 5 (11-10-2011)
  • HAL Id : inria-00185271 , version 2
  • ARXIV : 0711.0694
Bruno Scherrer. Performance Bounds for Lambda Policy Iteration. [Research Report] 2007, pp.35. ⟨inria-00185271v2⟩
326 Consultations
327 Téléchargements
