Fitted Q-iteration in continuous action-space MDPs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2007
Rémi Munos
  • Fonction : Auteur
  • PersonId : 836863
Csaba Szepesvari
  • Fonction : Auteur
  • PersonId : 844057
We consider continuous state, continuous action batch reinforcement learning where the goal is to learn a good policy from a sufficiently rich trajectory generated by some policy. We study a variant of fitted Q-iteration, where the greedy action selection is replaced by searching for a policy in a restricted set of candidate policies by maximizing the average action values. We provide a rigorous analysis of this algorithm, proving what we believe is the first finite-time bound for value-function based algorithms for continuous state and action problems.
rlca.pdf (370.43 Ko) Télécharger le fichier
inria-00185311 , version 1 (05-11-2007)
inria-00185311 , version 2 (08-01-2008)
  • HAL Id : inria-00185311 , version 2
Andras Antos, Rémi Munos, Csaba Szepesvari. Fitted Q-iteration in continuous action-space MDPs. [Technical Report] 2007, pp.24. ⟨inria-00185311v2⟩
459 Consultations
779 Téléchargements
