Logol : Modelling evolving sequence families through a dedicated constrained string language - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The report reviews the key milestones that have been reached so far in applying formal languages to the analysis of genomic sequences. Then it introduces a new modelling language, Logol, that aims at expressing more easily complex structures on genomic sequences. It is based on a development of String Variable Grammars, a formal framework proposed by D. Searls.
rcInriaLogol07.pdf (327.11 Ko) Télécharger le fichier
inria-00186568 , version 1 (09-11-2007)
inria-00186568 , version 2 (13-11-2007)
inria-00186568 , version 3 (15-11-2007)
  • HAL Id : inria-00186568 , version 1
Catherine Belleannée, Jacques Nicolas. Logol : Modelling evolving sequence families through a dedicated constrained string language. [Research Report] 2007, pp.19. ⟨inria-00186568v1⟩
249 Consultations
167 Téléchargements
