Nesting ocean models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2006
This note is focused on the problem of providing boundary conditions for regional ocean models. It is shown that usual methods generally do not address the correct problem, but more or less approaching ones. A tentative classification of these methods is proposed. Then their theoretical foundations are discussed, and recommendations are given.
version-finale.pdf (2.71 Mo) Télécharger le fichier
inria-00187576 , version 1 (14-11-2007)
Eric Blayo, Laurent Debreu. Nesting ocean models. Eric P. Chassignet; Jacques Verron. An Integrated View of Oceanography: Ocean Weather Forecasting in the 21st Century, Kluwer, 2006, 978-1-4020-4028-3. ⟨10.1007/1-4020-4028-8_5⟩. ⟨inria-00187576⟩
116 Consultations
574 Téléchargements
