An introduction to algebraic discrete-time linear parametric identification with a concrete application - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal Européen des Systèmes Automatisés (JESA) Année : 2008
An algebraic framework for continuous-time linear systems identification introduced in the literature some years ago has revealed as an interesting alternative way for on-line parametric identification. The present contribution aims at conveying those ideas to linear time-invariant discrete-time systems, with particular emphasis attached to application issues. To this end, an on-line linear identifier for n-th order systems is evolved, re-sorting to the operational representation of the dynamics. Being discussed on the basis of a fifth-order model of a drive-train, the numerical condition of the obtained setting of the identifier is found to suffer significantly with decreasing sampling times. A setting not experiencing these numerical problems is finally introduced by means of a re-parametrization of the identifier via application of the bilinear Tustin transform. The already implemented computer programs, where computer algebra plays an important role, are available.
Discridentif-JESA.pdf (206.49 Ko) Télécharger le fichier
inria-00188435 , version 1 (16-11-2007)
inria-00188435 , version 2 (09-04-2008)
  • HAL Id : inria-00188435 , version 2
Michel Fliess, Stefan Fuchshumer, Markus Schöberl, Kurt Schlacher, Hebertt Sira-Ramirez. An introduction to algebraic discrete-time linear parametric identification with a concrete application. Journal Européen des Systèmes Automatisés (JESA), 2008, 42 (2-3), pp.210--232. ⟨inria-00188435v2⟩
644 Consultations
510 Téléchargements
