Multimedia Authoring for Communities of Teachers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Web-Based Learning and Teaching Technologies Année : 2007
Jan Mikác
  • Fonction : Auteur
  • PersonId : 844602
Romain Deltour
  • Fonction : Auteur
  • PersonId : 844603
One way of providing technological support for communities of teachers is to help participants to produce, structure and share information. As this information becomes more and more multimedia in nature, the challenge is to build multimedia authoring and publishing tools that meets requirements of the community. In this paper we analyze these requirements and propose a multimedia authoring model and a generic platform on which specific community-oriented authoring tools can be realized. The main idea is to provide template-based authoring tools while keeping rich composition capabilities and smooth adaptability. It is based on a component-oriented approach integrating homogeneously logical, time and spatial structures. Templates are defined as constraints on these structures.
IJWLTT.pdf (645.72 Ko) Télécharger le fichier
inria-00189319 , version 1 (20-11-2007)
  • HAL Id : inria-00189319 , version 1
Agnès Guerraz, Cécile Roisin, Jan Mikác, Romain Deltour. Multimedia Authoring for Communities of Teachers. International Journal of Web-Based Learning and Teaching Technologies, 2007, 2 (3), pp.1-18. ⟨inria-00189319⟩
161 Consultations
2008 Téléchargements
