Using Wikipedia Categories and Links in Entity Ranking - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Anne-Marie Vercoustre
  • Fonction : Auteur
  • PersonId : 830030
Jovan Pehcevski
  • Fonction : Auteur
  • PersonId : 830040
This paper describes the participation of the INRIA group in the INEX 2007 XML entity ranking and ad hoc tracks. We developed a system for ranking Wikipedia entities in answer to a query. Our approach utilises the known categories, the link structure of Wikipedia, as well as the link co-occurrences with the examples (when provided) to improve the effectiveness of entity ranking. Our experiments on the training data set demonstrate that the use of categories and the link structure of Wikipedia, together with entity examples, can significantly improve entity retrieval effectiveness. We also use our system for the ad hoc tasks by inferring target categories from the title of the query. The results were worse than when using a full-text search engine, which confirms our hypothesis that ad hoc retrieval and entity retrieval are two different tasks.
inex07.pdf (165.03 Ko) Télécharger le fichier
inria-00192489 , version 1 (28-11-2007)
Anne-Marie Vercoustre, Jovan Pehcevski, James A. Thom. Using Wikipedia Categories and Links in Entity Ranking. Proceedings of the sixth International Workshop of the Initiative for the Evaluation of XML Retrieval (INEX 2007), Dec 2007, Schloss Dagstuhl, Germany. pp. 321-335, ⟨10.1007/978-3-540-85902-4_28⟩. ⟨inria-00192489⟩
Collections
INRIA INRIA2
209 Consultations
786 Téléchargements
