Multi-Output Dependent Observability Normal Form - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Nonlinear Analysis: Theory, Methods and Applications Année : 2009
This article gives the sufficient condition which guarantees the existence of a reference frame in which a multi-output nonlinear system is linearizable with a linear part depending on its outputs. Our method is based on the design of a reference frame associated with nonlinear observable systems. Moreover, we give the generalization of the result obtained in [5] and [19]. And some examples are given in order to highlight our thinking.
Automatique
NA_HAL.pdf (195.75 Ko) Télécharger le fichier
inria-00192960 , version 1 (29-11-2007)
inria-00192960 , version 2 (02-12-2007)
Gang Zheng, Driss Boutat, Jean-Pierre Barbot. Multi-Output Dependent Observability Normal Form. Nonlinear Analysis: Theory, Methods and Applications, 2009, 70 (1), pp.404-418. ⟨10.1016/j.na.2007.12.012⟩. ⟨inria-00192960v2⟩
306 Consultations
249 Téléchargements
