A reduced polytopic LPV synthesis for a sampling varying controller : experimentation with a T inverted pendulum - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Olivier Sename
Daniel Simon
This paper deals with the adaptation of a real-time controller's sampling period to account for the available computing resource variations. The design of such controllers requires a parameter-dependent discrete-time model of the plant, where the parameter is the sampling period. A polytopic approach for LPV (Linear Parameter Varying) systems is then developed to get an $H_{\infty}$ sampling period dependent controller. A reduction of the polytope size is here performed which drastically reduces the conservatism of the approach and makes easier the controller implementation. Some experimental results on a T inverted pendulum are provided to show the efficiency of the approach.
Automatique
drosds518.pdf (708.37 Ko) Télécharger le fichier
inria-00193862 , version 1 (04-12-2007)
  • HAL Id : inria-00193862 , version 1
David Robert, Olivier Sename, Daniel Simon. A reduced polytopic LPV synthesis for a sampling varying controller : experimentation with a T inverted pendulum. ECC 2007 - European Control Conference, Jul 2007, Kos, Greece. ⟨inria-00193862⟩
205 Consultations
253 Téléchargements
