Certified exact real arithmetic using co-induction in arbitrary integer base - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Nicolas Julien
  • Fonction : Auteur
  • PersonId : 836843
In this paper we describe some certified algorithms for exact real arithmetic based on co-recursion. Our work is based on previous experiences using redundant digits of base 2 but generalizes them using arbitrary integer bases. The goal is to take benefit of fast native integer computation. We extend a technique to compute converging series. We use this technique to compute the product and the inverse. We describe how we implement and certify our algorithms in the proof system Coq and evaluate the efficiency of the library inside the prover.
exactreals.pdf (185.7 Ko) Télécharger le fichier
inria-00202744 , version 1 (08-01-2008)
  • HAL Id : inria-00202744 , version 1
Nicolas Julien. Certified exact real arithmetic using co-induction in arbitrary integer base. FLOPS 2008, Apr 2008, ISE, Japan. ⟨inria-00202744⟩
Collections
INRIA INRIA2
126 Consultations
216 Téléchargements
