A First Experimentation on High-Level Tooling Support upon Fractal
In this abstract, we present a first experimentation on tooling support based on Fractal component model. The motivations which encouraged us were to provide an homogeneous design environment for the user to specify Fractal applications.
Génie logiciel [cs.SE]
