IP Simulator User Guide - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2008
Emmanuel Nataf
This simulator allows to construct IPv4 network topologies with routers and end hosts. The focus of the simulator is on routing table configuration. The simulator could also run user network programs written with a java.net UDP like API.
SimulIP.pdf (452.1 Ko) Télécharger le fichier
inria-00205033 , version 1 (16-01-2008)
inria-00205033 , version 2 (17-01-2008)
  • HAL Id : inria-00205033 , version 1
Emmanuel Nataf. IP Simulator User Guide. [Technical Report] 2008, pp.19. ⟨inria-00205033v1⟩
104 Consultations
458 Téléchargements
