Real-time rendering and editing of vector-based terrains - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Graphics Forum Année : 2008
We present a method to populate very large terrains with very detailed features such as roads, rivers, lakes and fields. These features can be interactively edited, and the landscape can be explored in real time at any altitude from flight view to car view. We use vector descriptions of linear and areal features, with associated shaders to specify their appearance (terrain color and material), their footprint (effect on terrain shape), and their associated objects (bridges, hedges, etc.). In order to encompass both very large terrains and very fine details we rely on a view dependent quadtree refinement scheme. New quads are generated when needed and cached on the GPU. For each quad we produce on the GPU an appearance texture, a footprint texture, and some object meshes, based on the features vector description and their associated shaders. Adaptive refinement, procedural vector features and a mipmap pyramid provide three LOD mechanisms for small, medium and large scale quads. Our results and attached video show high performance with high visual quality.
article.pdf (1.45 Mo) Télécharger le fichier
dataset.avi (2.2 Mo) Télécharger le fichier
editing.avi (8.4 Mo) Télécharger le fichier
flyover.avi (8.77 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
Format : Autre
Format : Autre
inria-00207679 , version 1 (18-01-2008)
Eric Bruneton, Fabrice Neyret. Real-time rendering and editing of vector-based terrains. Computer Graphics Forum, 2008, Special Issue: Eurographics '08, 27 (2), pp.311-320. ⟨10.1111/j.1467-8659.2008.01128.x⟩. ⟨inria-00207679⟩
3131 Consultations
5732 Téléchargements
