An alternating linearization bundle method for convex optimization and nonlinear multicommodity flow problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
We give a bundle method for minimizing the sum of two convex functions, one of them being known only via an oracle of arbitrary accuracy. Each iteration involves solving two subproblems in which the functions are alternately represented by their linearizations. Our approach is motivated by applications to nonlinear multicommodity flow problems. Encouraging numerical experience on large scale problems is reported.
kiwiel-albm.pdf (253.17 Ko) Télécharger le fichier
inria-00208074 , version 1 (19-01-2008)
inria-00208074 , version 2 (21-01-2008)
  • HAL Id : inria-00208074 , version 1
Krzysztof C. Kiwiel. An alternating linearization bundle method for convex optimization and nonlinear multicommodity flow problems. [Research Report] 2008. ⟨inria-00208074v1⟩
177 Consultations
276 Téléchargements
