Space Time relaying versus Information Causality - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
Philippe Jacquet
We investigate the connection between causality and Information Theory. We show that a simple reading of Information Theory makes that quantum entanglement allows super-luminal information transfer. We show that introducing the concept of space-time information relaying partially solves the paradox of non causal information transfer. Surprisingly information causality is only dependent on the quantum unitarity which is a weaker principle than physical causality.
space-time-RR.pdf (184.67 Ko) Télécharger le fichier
inria-00216180 , version 1 (24-01-2008)
inria-00216180 , version 2 (25-01-2008)
  • HAL Id : inria-00216180 , version 1
Philippe Jacquet. Space Time relaying versus Information Causality. [Research Report] 2008, pp.15. ⟨inria-00216180v1⟩
112 Consultations
158 Téléchargements
