A multithreaded communication engine for multicore architectures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
The current trend in clusters leads towards an increase of the number of cores per node. As a result, an increasing number of parallel applications is mixing message passing and multithreading as an attempt to better match the underlying architecture's structure. This naturally raises the problem of designing efficient, multithreaded implementations of MPI. In this paper, we present the design of a multithreaded communication engine able to exploit idle cores to speed up communications in two ways: it can move CPU-intensive operations out of the critical path (e.g. PIO transfers offload), and is able to let rendezvous transfers progress asynchronously. We have implemented these methods in the PM2 software suite, evaluated their behavior in typical cases, and we have observed good performance results in overlapping communication and computation.
main.pdf (212.16 Ko) Télécharger le fichier
inria-00224999 , version 1 (30-01-2008)
François Trahay, Elisabeth Brunet, Alexandre Denis, Raymond Namyst. A multithreaded communication engine for multicore architectures. Communication Architecture for Clusters, Apr 2008, Miami, United States. ⟨10.1109/IPDPS.2008.4536139⟩. ⟨inria-00224999⟩
261 Consultations
283 Téléchargements
