Fluctuations of Interacting Markov Chain Monte Carlo Models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
We present a functional central limit theorem for a general class of interacting Markov chain Monte Carlo interpretations of discrete generation measure-valued equations. The path space models associated with these stochastic processes belong to the class of nonlinear Markov chains interacting with their empirical occupation measures. We develop an original theoretical analysis based on resolvent operators and semigroup techniques to analyze the fluctuation of their occupation measures around their limiting value. We also present a set of simple regularity conditions that applies to interacting Markov chain Monte Carlo models on path spaces, yielding what seems to be the first fluctuation theorems for this class of self-interacting models.
i-mcmc-gtcl-bdd.pdf (221.64 Ko) Télécharger le fichier
inria-00227536 , version 1 (31-01-2008)
inria-00227536 , version 2 (01-02-2008)
inria-00227536 , version 3 (04-02-2008)
inria-00227536 , version 4 (04-02-2008)
inria-00227536 , version 5 (05-02-2008)
  • HAL Id : inria-00227536 , version 1
Bernard Bercu, Pierre del Moral, Arnaud Doucet. Fluctuations of Interacting Markov Chain Monte Carlo Models. [Research Report] 2008, pp.20. ⟨inria-00227536v1⟩
310 Consultations
266 Téléchargements
