Derivation of a non-hydrostatic shallow water model; Comparison with Saint-Venant and Boussinesq systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
From the free surface Navier-Stokes system, we derive the non-hydrostatic Saint-Venant system for the shallow waters including friction and viscosity. The derivation leads to two formulations of growing complexity depending on the level of approximation chosen for the fluid pressure. The obtained models are compared with the Boussinesq models.
JSM-MOB.pdf (366.19 Ko) Télécharger le fichier
inria-00232824 , version 1 (01-02-2008)
inria-00232824 , version 2 (15-02-2008)
inria-00232824 , version 3 (18-02-2008)
  • HAL Id : inria-00232824 , version 1
  • ARXIV : 0802.0250
Jacques Sainte-Marie, Marie-Odile Bristeau. Derivation of a non-hydrostatic shallow water model; Comparison with Saint-Venant and Boussinesq systems. [Research Report] 2008, pp.33. ⟨inria-00232824v1⟩
316 Consultations
655 Téléchargements
