Stabilization of explicit coupling in fluid-structure interaction involving fluid incompressibility - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
In this work we propose a stabilized explicit coupling scheme for fluid-structure interaction problems involving a viscous incompressible fluid. The coupled discrete formulation is based on Nitsche's method with a time penalty term giving L^2-control on the fluid force variations at the interface. The scheme is stable, in the energy norm, irrespectively of the fluid-structure density ratio. Numerical experiments, in two and three dimensions, show that optimal time accuracy can be obtained by performing a few defect-correction iterations
RR-6445.pdf (2.49 Mo) Télécharger le fichier
inria-00247409 , version 1 (07-02-2008)
inria-00247409 , version 2 (11-02-2008)
inria-00247409 , version 3 (11-02-2008)
inria-00247409 , version 4 (23-10-2008)
  • HAL Id : inria-00247409 , version 3
Erik Burman, Miguel Angel Fernández. Stabilization of explicit coupling in fluid-structure interaction involving fluid incompressibility. [Research Report] RR-6445, 2008. ⟨inria-00247409v3⟩
Collections
INRIA-RRRT
207 Consultations
1301 Téléchargements
