Gathering with Minimum Delay in Sensor Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2008
Data gathering is a fundamental operation in wireless sensor networks in which data packets generated at sensor nodes are to be collected at a base station. The network is a multi-hop wireless network and the time is slotted so that one--hop transmission of one data item consumes one time slot. In this paper we suppose that each sensor is equipped with an half--duplex interface; hence, a node cannot receive and transmit at the same time. Moreover, each node is equipped with omnidirectional antennas allowing the transmission over distance R. We model the network with a graph where the vertices represent the nodes and two nodes are connected if they are in the transmission/interference range of each other. Due to interferences a collision happens at a node if two or more of its neighbors try to transmit at the same time. Furthermore we suppose that an intermediate node should forward a message as soon as it receives it. We give an optimal collision free gathering schedule for tree networks.
sensor-feb08.pdf (214.32 Ko) Télécharger le fichier
inria-00256896 , version 1 (18-02-2008)
  • HAL Id : inria-00256896 , version 1
Jean-Claude Bermond, Luisa Gargano Adele Rescigno. Gathering with Minimum Delay in Sensor Networks. 2008. ⟨inria-00256896⟩
199 Consultations
75 Téléchargements
